What Engine Oil & Trans Fluid works best for 53 Hudson Hornet
Hoping you guys can put me in the right direction, I have gone through some posts and just want to make sure I am using the right fluids on todays market.
For the Motor Oil the manual says S.A.E. 30..... I live in the warmest part of Canada, rarely goes below 10deg fahrenheit so I am assume any 10w30 grade would work however I will not be driving it in the winter months.
For the Trans Fluid the manual says 2 pounds of S.A.E 90 E.P. gear oil..... this one has me baffled... any ideas on what I should use?
Thanks
Gord
https://smile.amazon.com/Lucas-Oil-10679-10W-30-Petroleum/dp/B009M64CAW
