Gas millage
tenbroecktenbroeck Posts: 16Member
I have a 41 8cyl w/overdrive and I only get 12 mpg on the hiway. My engine has been rebuilt plus it only has 47k orig mileage. comp is 100psi any suggestions
  • squirrelsquirrel Posts: 138Member
    enjoy the drive!
  • Jon BJon B Posts: 6,906Administrator
    Are you sure your odometer is correct?  Have you tested it (by comparing the odometer readings to the mileposts on your nearest Interstate highway)?  I would try verifying that for starters, so you're sure you're dealing with the right numbers.
  • 50C8DAN50C8DAN Posts: 1,779Senior Contributor
    I have gotten as high as 18, and most often 16 on my '50 C8 3spd w/ OD (Supermatic rear), 12 seems a bit low to me.
  • tenbroecktenbroeck Posts: 16Member
    I will check my odometer. thanks
