Need intake manifold 308
TheSweed1TheSweed1 Posts: 6Member
I have a 1951 308 6 cyl and need a used aluminum intake manifold that will be modified to run three Holley 1904 glass bowl 1 barrel carbs. I am putting the engine together to run at The Race of Gentlemen in Wildwood NJ. Also any suggestions on a good cam would be appreciated. This car will be run on the street also not just race.   Thank you  Warren
  • TheSweed1TheSweed1 Posts: 6Member
    Does anyone know who makes the side draft webber manifolds? I could modify a set of those to work buy building a log intake that bolts to them.
  • 54coupe54coupe Posts: 195Member
    Clifford Performance made them. I don't know if they have any in stock
    Thank you 54 coupe I will give them a call
