54 Stepdown speedometer cable
Well... while waiting for the day to change the leaking seal on the trans. my speedometer cable got broke.
But since the removal process was easy so far, might as well, try to help some folks while changing the cable.
As you can see, it needs to be changed, but I've observed that the cable broke near the end that is connected to the speedometer gear located in the automatic transmission. Could the speedometer gears have slipped enough to break the cable ? Also, does changing the cable is as easy as connecting the two ends to their respective place or is it more complicated ? As always, advices from the experts are welcome.
In the meantime, I'll try to find the proper cable and give more pictures on how to change it for the club : it can be useful for someone
Thanks in advance,
Max
Thanks in advance,
Max
As for the speedometer, I did removed it from the cluster as I was curious to see how it works and if it was broken.
So far, it is turning freely and seems to be still intact.
As for this part here, one end goes into the trans. driving the speedometer gear while the other end is where the cable is connected from what I've seen.
it has been a couple of days that I'm trying to fix the speedometer cable and i'm struggling with it. Every time I thought I've fixed it, I do a road test and the cable comes free again.
This little fella is giving me the trouble as it always comes free from the cable, even when it was crimped on it ( though it could be me not knowing how to use the crimping tool that comes with the cable kit ), and I have tried many attempts to jam it tight on the cable. Right now I'm running out of ideas to fix the easy trouble that is the speedometer cable. I don't know if there's something I'm missing or done wrong, but any advices or corrections are welcome.
Max
The speedometer cable ends are SWEDGED onto the flexible cable piece. Swedging the cable requires extreme force to assure the two pieces are affixed to one another.
Does the cables themselves ( not the jackets ) are of the same diameter, regardless the car application? If not, what is the exact cable diameter Hudson used for their speedometer cable? As my potencial idea would be to get a speedometer cable that has the exact length so it would be way easier to fix.
Dang it, I would have loved to think of this sooner lol.
I reveived the cable I ordered, but unfortunately upon installing it was too long by 2 inches. Luckly, I kept the previous cut-to-fit cable and lend it to my boss ( a good car mechanic ) to fix the tip as it should be.
After installing the cable, I did a road test... to see the speedo not moving at all and hear the cable sort of running free.
" Ah crap, here we go again..."
I did check the cable and to my relief, it was still in one piece. So i decided to check the speedometer itself and do some deeper tests on it.
"Well, at least I haven't really bought the cable for nothing."
From the test I discovered that the problem did come from the speedo as, while turning the gears, it was turning fine for a while until it became a bit harder to finally turning fine again. there might be something in the gears that make speedo stuck.
From now on I'm asking if it is possible to save this speedo, and if yes, what would be the procedure. Any advices or corrections are welcome.
Max
My experience with speedos is the vast majority just need to be cleaned and lubricated with a light oil. It does not take much to get it working correctly and you don't want to contribute to a future sticking and gumming problem with to much oil. I have brought back to life the speedo on my 1910, 1922, 1946, three stepdowns and my 1960 dodge matador this way. The biggest pain was removing and install the speedos. I also use a drill connected to a broken cable as a drive. Somewhere I was reading that 1009 revolutions is the standard for a mile on most speedos. But some do vary. Lots of good info if you look around.
Jay
As for the cable, I only bought the inner cable with the jacket to then only se the inner one as I wanted to do. I didn't wanted to change the entire cable with the housing as I was afraid to be unable to find the proper housing that can fit into the car.
"Huzzah ! "
Though running fine, I've observed that the speedo needle was a bit bouncy, but not too much. Could this be a symptom of a future issue or was it a normal occurrance of the speedo ?
Again, thank you very much for your help, for sure I've learned alot about the speedometer
It could just be lubrication or lack there of with some parts still just a bit sticky. However, some speedo do use pot metal cast parts. These parts will go bad, it is just a matter of time before they swell and fall apart. I have found that many of the early speedos go through changes to the mechanics during a production run. The physical look may not change but the internal parts may. So on my 1922, I had one speedo that had pot metal parts for the odometer gears. Another identical looking unit made a bit earlier had brass odometer parts. I just swapped them out and no one will ever know.
Jay
