Door weatherstripping pictures needed
schillazschillaz Posts: 285Expert Adviser
I am working on putting the door weatherstripping in on a 1949 coupe. Can someone post pictures of the weather stripping correctly installed?
I have what I believe is the correct parts from WRP but want to make sure I install it correctly.
My area of question is mainly the door jam with the S piece and what else is needed up and down from there.
  • GlowplugGlowplug Posts: 1,975Expert Adviser
    Go to my website and select : https://hudsonrestoration1948-54.com
    Select body work and trim - middle of page complete write up with pictures.  Same for coupe or sedan.
  • schillazschillaz Posts: 285Expert Adviser
    Perfect, thanks!
    I also found where those windshield drain tubes go....from using your website!
    thank you very much.
