46. 254 rotor
paulrhd29nzpaulrhd29nz Posts: 211Member
Does any one have a Napa part number for the rotor?
  • railknightrailknight Posts: 380Expert Adviser
    edited June 2019
    I don't know if this will help, but I have an old January, 1958 NAPA catalog and it shows under Hudson distributor rotors: "All 8 cyl. (exc. Hornet 50) … 37-47 Echlin AL-46  suggest retail price .62"
  • LanceLance Posts: 879Member
    I have those rotors. I think NAPA may have discontinued those numbers don't know for certain
  • BigSkyBigSky Posts: 547Senior Contributor
    This is what I have listed for my 1937 254 engine, you’ll have to see if it may work.
    Rotor: Standard Motor Parts AL-102 (AL64??),  NAPA AL32.
    Don't see any of the correct parts here.  OEM   number was IG 1325 none of those are the correct style.  The rotor for the 48-52 254 was similar but was not the same as the earlier 8 cylinder version.
    It’s probably the best thing to order those from Wildrick Restoration.  This maybe the items, but call & talk to Cole there, he’ll fix ya up.
    https://www.wrphet.com/engine.html
    Railknight I have those if you are interested.
  • paulrhd29nzpaulrhd29nz Posts: 211Member
    Thanks everyone. I’ll be calling you Lance
    I found my Hudson Swap Manuel and parts interchange book. It list my cap and rotor as
    AL59 and AL58  for 35-47 8cyl.
    Paul   my number is 704 792 911 zero.
  • Uncle JoshUncle Josh Posts: 2,645Senior Contributor
    Rotor 254 eight
    Standard
    AL99
    Delco
    E739A
