where to buy/rebuild a '52 Hornet water pump
devindevin Posts: 44Member
I see Jeremy Burris in the WTN rebuilds splasher pumps. I'll check with him regarding my situation. Might you have any suggestions?
Thank you.
  • ski4life65ski4life65 Posts: 947Expert Adviser
    Pretty sure Dale Copper sells brand new ones (not rebuilt)
  • squirrelsquirrel Posts: 26Member
    I just bought a new pump from eBay, in New Jersey, it is working fine so far.
    I expect there are a few others that sell the same pump.
  • KdancyKdancy Posts: 2,316Senior Contributor
  • LanceLance Posts: 746Member
    How many do you need?
  • devindevin Posts: 44Member
    Just ordered one from Dale. Thank you for your assistance!
    Now I need a 160 thermostat which Dale doesn't supply. Any one have one for sale?
  • GlowplugGlowplug Posts: 1,646Expert Adviser
    Devin go to my website and select cooling which brings you to a page where you will find suggestions for making your cooling system more efficent.
    https://hudsonrestoration1948-54.com/
    Use Mr Gasket thermostat available from local auto parts stores or on line
    thank you! According to Dale, I'll need the correct Hudson thermostat otherwise I'll need to modify the waterpump. Do you concur?
    Devin I am using the bypass mod with a mr gasket thermostat with Dales new water pump installed on 2 different Hudson engines.  Proper cooling with a lower max operating temperature.
  • RichardDRichardD Posts: 600Member
    edited May 16
    Here is the thermostat I use, more than double the flow potential. Shown with the "normal" one used.
    Also be sure you are using the correct WP pulley for correct water flow rate: 5 inches in diameter is best. 2 cents~~~
    800 x 600 - 333K
