Need this piece....
1949 Hudson Super...
The piece is located on the driver's side at the edge of the fender, surrounding the grille.
  • At the risk of being thought of as a jerk, I would ask why don't you just bondo over the hole and sand it down instead of going to the trouble of tearing your front sheet metal apart. Just curious.
  • Or take it off and have a welder fill the hole and grind it smooth....
    Yep, 10 minute job with a wire welder and a file.
  • Ken U-Tx said:
    For something like that, thin metal, probably with deep rust pitting on the back side, if I was to weld it, MIG may just blast it away , so I would either gas weld it with a 000 tip and soft steel wire, or use lower heat silicon bronze alloy rod to fill the hole.
    Fully expected. I speak of experience. Somebody drilled a 3/8 hole in the hood of a tractor I have to mount something. I used my wire welder to fill the gap and ground the top pretty.
