modern high torque starter for manual trans application
Believe JasonNC has one; might search his posts.0
I’ve fitted one to a 35 H8, AFAIK what I did will work through to 54, have a look through my posts.0
Isn't the issue of using a modern starter knocking the ring off the flywheel? My Denso based starter has a spring loaded pinion, which would at least somewhat reduce that issue. It's also a much gentler engagement than a bendix.0
The Denso starter that I used engages from front of the flywheel, but very gently. The end of the pinion sits maybe 1/16” away from the flywheel, a not very powerful solenoid within the starter pushes the pinion into the ring gear. The starter cranks only when the pinion is fully extended. To me, having the Denso starter push the ring gear off the flywheel is not an issue.
To make doubly sure (I’m not going to do this) it would be possible to attach ring gear keepers to the flywheel using the pressure plate bolts.
That was something that concerned me when I was contemplating a mini starter but others who had trodden the path assured me that the beveled pinion teeth and square ring gear teeth play nicely together. My experience with my set up is that it works just fine.
Same here on both my Hudsons...0
G'day All
My 8 cyl has a honda civic high torque starter with a custom made spacer plate on the front of the starter
Works fine
Phil0 -
Did that starter come with the correct pinion? 9 tooth x 28mm OD from memory?0
Bob
I'll have to check next day or so
Watch this space
phil0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
