adding an additional brake/signal light
Val
Val Member
edited August 2018 in HUDSON
I would like to add an additional light such as a light bar for my 39 series 92 but not sure where I would mount it. Has any one else done this on their late 30s cars?
  • Glowplug
    Glowplug Expert Adviser
    "third" brake lights can be affixed to the rear window glass via suction cups or even if desired the suction cups can be double back taped to the glass.  Run the wires via the outside of the window molding.
  • Val
    Val Member
    Thanks Oldfarmer  since my rear windows are split that would be the best option I guess as the body is a smooth slope downward and nowhere else really to mount a third light  set up
  • Val
    Val Member
    But do those light bars come as 6 volt? I may have to modify if they don't.
  • >>>  https://vimeo.com/120428548/be85171744
    This is on a stepdown but you should try to get one that will give signals, etc.
  • jjbubaboy
    jjbubaboy Senior Contributor
    Heres the one I have. Works great!
    Can mount with suction cups or supplied 'sticky dots'.
    Ran the wires down into the trunk and tied into the wiring there.
    Jeff
    http://jandlenterprise.com/products/brakelighter.htm
  • Both links above are showing the same product (the best).
  • Val
    Val Member
    Thanks guys that looks perfect!
