53 Wasp directional lights. “Blinkers”
Im guessing you are shorting out.Also check grounds.if that dosnt work get out the multimeter and start testing. or a simple test light. turn on the blinkers and test the wire/terminal leaving the unit. It will be left, ground & right. If it blinks then move further along the wire or skip to the cars light assembly and test there.Are the 53 blinker/brake light same bulb or two separate bulbs?0
Single bulbs. I’ve narrowed it down to the directional switch. I need to find a working one or see what I can do with the original.0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
