One more time on the 16" wheels
Still looking to figure out what the correct wheels were for 34 Terraplane K coupe with the optional 16" wheels. I'm not sure why, since the closest I have gotten to finding any were 2 Hudson 16" wheels. BUT, in case I ever find any that anybody will sell, were they spoked like 17's, or the "artillery" style?
Wheels were optional wire or steel, both 16" and 17" for 1934, so it's your choice.0
Geoff; thanks very much. I was going to get some of those new original-sized radials (Available in 16" and 17") and I just thought the 34 coupe would look better with the 16s. You'd think the 16" wheels would not be so hard to find; as I mentioned, so far the closest I have come is 2 Hudson 16" wheels, which hopefully would take the Terraplane hubcap.0
AFAIK Terras and Hudsons mostly used the same wheel so T & H hubcaps will interchange. Vague memory says the wheels on the LWB Hudson may have been different.0
I remember in my storage unit - not here at the house in SLC, UT I have some Hudson 8 artillery wheels from a 1934. I could go check if of interest and you think they would work. Gert Kristiansen.0
From the 1930-39 parts book, # 43728 was used on 1933 K,KU,KT as well as 1934 Terraplane K,KU and 1934 Hudson LT,LS This was a 16" wire wheel which was standard on th 33 KT optional on the K and KU. This was the standard wire wheel on the LT and LTS Hudsons, Optional for the 34 Terraplane K,KU. Don't know if this helps, is a bit confusing!
"Ric"0 -
S.W.B. Hudsons, '34-'35 all have 4 bolt wheels, and are interchangeable with Terraplane.0
bob ward said:AFAIK Terras and Hudsons mostly used the same wheel so T & H hubcaps will interchange. Vague memory says the wheels on the LWB Hudson may have been different.
The LWB wheels are wooden spoked rims, can not remember if they were 5 stud though. I have a feeling they were. Big steel centres.0 -
dholck said:Geoff; thanks very much. I was going to get some of those new original-sized radials (Available in 16" and 17") and I just thought the 34 coupe would look better with the 16s. You'd think the 16" wheels would not be so hard to find; as I mentioned, so far the closest I have come is 2 Hudson 16" wheels, which hopefully would take the Terraplane hubcap.
I have restored both 1934 and 1935 here in Australia and yes the 16" wheels look much better than the 17".
Hi Thee.
Trevor NZ here. The radials I use here are Bridgestone duelers size 205 R 16 C. We get them very cheap here they come on Toyota Hilux and similar Utes . Farmers take them off and put more aggressive tyres on them I use them on all my Terraplane and Hudson cars I don't even have to use a tube in them totally transforms the handling. They are probably available in aussie as well. I have brought for as low as $30.00 here
TKS Courtesy Man; from what I see from other online resources, the difference between the 34 Terraplane K 16" wheels (16X6.00 tires) and the Hudson 8 wheels is that the Hudson 8s had 16X6.25 and 16X6.5 tires. Of course a major factor is the 4 bolt vs 5 bolt - Terraplane has 4-bolt.0
The 34 and 35 Hudson 8 coupes also have the 4 bolt rims. Trevor NZ0
The 1934 H 8 wheels I have are 16 inch and 4 bolt artillery style. I know the cost of shipping would be a problem. Also have 4 whitewall tires 6 x 16 that I don't need. My email HETgtkristi@comcast.net Thanks Gert (ghiet)0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
- 591 Vehicles
