Front end shimmy?
hudsonsplasher1
hudsonsplasher1 Senior Contributor
Hi all, looking for some info on what it takes to stop front end shimmy on a 49 step down. I know it has old tires which I assume adds to the problem, and I imagine warn bushings will add to it too. Any ideas what to start with?
  • Check for problems in the entire steering system. Start with the tie rod ends. Then check the center point steering bracket including the ball end , needle bearings and pin. Check and make sure the 3 bolt center point steering is indeed bolted at 3 points. Check the drag link for lubrication and adjustment.Then check the tie rods themselves. Check the steering box and the gears inside . Check for lubrication level in the steering box. Check for kingpin wear . Check for steering arm wear. Check your tires for both being the same size
  • Browniepetersen
    Yep, and while you are checking them all--replace them.
  • Make sure your shock absorbers are working properly.  If you have old tires, maybe biasply  with tubes, they can be the culprit for sure.  And what lance and Browniepetersen said.
  • Geoff
    Geoff Senior Contributor
    First thing I would do is get the wheels balanced.
  • hudsonsplasher1
    Thanks for your input, much appreciated.
