50 head and block numbers.
hudsonsplasher1
Hi all, need some help. These number are on the head of a 1950 Hudson Commodore Six, 30366-1-a, and 5029988-1 on the block. No 232, or 262 number embossed on the head. Can anyone tell me if this is a 232 or 262 motor that they used in 1950, or if it's correct for the year?
Thanks in advance.
Gene.
Thanks in advance.
Gene.
hi gene, fred has all the info you need on those numbers.0
If the serial # on the front of the block matches the tag on drivers door post then it is a 262. The 262's also originally had a 2 bbl. carb/intake. The block casting # (hidden by the distributor) is the same for both engines. Differences are length of crankshaft stroke
and piston pin height.
The 1948-1950 engines were referred to as the narrow block. and did not have the cu in cast on the front of the head.
My website contains a link to Engines. This linked page contains information to decipher engine markings.
http://hudsonrestoration1948-54.com/Engine.htm
Thanks a lot guys, much appreciated.
