Engine/transmission ID
scottyrodgers
Attacked are the serial numbers from my hornet body,engine, tranny. Doing the research pretty confident the body and chassis are a 54 from july. Cant find anything about engine and tranny numbers. I assume they are the same as the body but engine has a set on the bottom left below the genny that says 10-6-52 and above the distributer are the rest of the sn. From the list used to id the body it doesnt show a hornet from 50 to 54 coming with a 262 only jets super wasp and commodore knowing the eng/tranny is a must so i get the correct parts. Any ideas????
Are you sure it is a 262, and not a 308 with a 262 head?
Go to my website, under Engines the information is posted there. Looking at what you posted, probably a 1952/262 Engine. No bottom rib on block, definitely not a 308. Serial numbers for installation that match body tag are stamped into block at front top of block below head, left side.0
304299 is a 1951-1953 casting for the 232- 262 your casting date indicates it was cast for the 1953 model year. The only difference between 232 and 262 is the stroke made possible by a different crankshaft. Don't know what else you need.
Have fun!0 -
Oops, forgot that the 232 has different pin height pistons, same bore but different pin location. Best bet though is this is a 262.0
Probably the car at one time blew engine and was replaced with a 52 engine? because hydra matic is a h52 .The 54 hydra matic tranny number is H 54 Ray
Would this make a difference in the distributor and all ignition components??? Maybe im putting the wrong cap rotor coil etc and thats why i get no ignition0
Ignition components are the same, 51-56 for the six.0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
