Rear Quarter Window Glass
I am replacing the rubber seals around the rear quarter windows (pivot) on my 52 Hornet Sedan. The body manual says to: 1. Remove the three sheet metal screws attaching garnish
moulding to window opening, 2. Push glass inward and remove glass, weatherstrip and
frame. For installation, it says to reverse the removal procedure. The process seems straightforward. Anything that I should know that is left out of the manual?
I purchased the seals from WRP. Do I need to use any type of sealant when installing the seal on the frame? Also, what should I use to connect the two ends to each other?
Thanks in advance for your assistance.
