Straight 8 tranny question
Hello guy's
I have got an 1951 straight 8 engine and I am looking for a manual transmission to go with this engine.
Does anybody know that the early transmission that went with a straight 8 have the same bolt patern as the later ones?
Ore even if the transmission of the six cylinder engines would bolt on.
Thank you
Philips Maeckel
Thank you
Philips Maeckel
48 -51 single lever transmissions are all the same.6 and 80
Couldn't darn near any Hudson manual transmission (1940-54) fit, if the correct bellhousing was used? 1941 and up, and the 1952-54 Borg Warners? I am not an expert in these years, but merely asking the question.0
I have a 1950 single lever O/D in my 39. Had to mod the X frame for it to fit. And I believe they used my original bell housing0
The Hudson single levers bolt to the bell housing with 6 bolts from the inside of the housing. The mid-52 on with the double levers used a different bell housing and the tranny bolted on with 4 bolts from the outside of the housing.0
Hudson still made the 8's in 1952. 1952 is when the Borg Warner double-levers came in, right? So the 52 (and up?) B-W double levers would fit the Hudson 8's -- if you used the 1952 bellhousing -- no?
The cool thing about using a '52 setup, is that with the B-W manual transmission, you can stick in a floor shifter from a Jeep or Studebaker truck, I believe.
Okay great!0
