1947Hudson Pickup
Is there another posting where you have described your problem, and things you have tried?0
Yes -sorry tried draining clutch and adding ketone and thinner .Are there any springs that hold linkage just doesn't look like everything is there0
Was the clutch working not long ago? Or is this a vehicle that's been in storage a long time.
If in storage, then the stuck clutch is normal and it's just a case of being patient, rotating the clutch and letting it sit for a day, pumping the clutch pedal, repeating.
If on the other hand the truck was working okay and then this suddenly happened, that could be another problem!
When you press on clutch pedal is it offering resistance (what you would expect, if it were a normally operating clutch)? Or is it suspiciously easy to press down?
