1955 needs help
Hey gang, need some help. Got a 1955 Hornet in the final stages of restoration. It has the V-8 with automatic. It is nearly impossible to start. It has the two stage fuel pump that is pumping gas- verified at carb. The carb is pumping gas. I have a blue spark at the plugs. I poured gas down the carb to start it and was able to back it out of the garage. Did some work on it and it will not start back up. It is original 6 volt positive ground system in it. Any suggestions?
Have you checked the distributor point gap?
