Hudson gas tank sending units FS
Although I have not been looking for one, I did back when I was getting my '50C8 back on the road and was lucky to find a NOS one. I see now where someone is reproing these:
http://www.ebay.com/itm/262909938411?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Based on the manner in which this product is described, my guess is that the someone is PAUL LARGETYPE.0
It has the right ID, location and use of CAPS!0
The Ford one will fit but won't read right
My Dakota Digital gauges came with a full sensor kit that includes a universal fuel sender.
No idea if it will work with Hudson tanks or with the stock Hudson gauges.
Resistance range 10-180ohms. 6inch to 23 inch deep tanks.
Summit sells them for $33.20
https://www.summitracing.com/int/parts/dak-sen-06-1/overview/
manuel:
http://www.dakotadigital.com/pdf/sen-06-1.pdf
Think I saw something about stock being 90ohms. Is that full or empty?
Summit search:
0empty - 90ohms full
https://www.summitracing.com/int/search/part-type/gauge-sending-units/gauge-type-application/fuel-level/sender-ohm-range/0-ohms-empty-90-ohms-full?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=fuel%20sender&N=4294927084%2B4294927080%2B4294927077
90full - 0 empty
https://www.summitracing.com/int/search/part-type/gauge-sending-units/gauge-type-application/fuel-level/sender-ohm-range/90-ohms-empty-0-ohms-full?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=fuel%20sender&N=4294927084%2B4294927080%2B4294789282
Mine reads around 10 ohms when full !!!
"Tanks" makes a unit like the one in the picture above.
Several different ohms units available.
You can use one for the Hudson if you turn the sending unit upside down.
Gauge will read ok.
Need to buy adapter so you can put a 5 hole unit on the 6 hole Hudson tank.
Sender about $35 Adapter about $35
After thinking about it....a Hudson sender either 6 or 12 volt would be the best.
It would fit & read the best.
I used the Tanks unit for my Sun Pro gas gauge. I modified the swing best I could...reads 7/8 when full and 1/8 when empty. I drove w/o a working gauge for 20 years. Used mileage. Now fool proof.
The right one is available from Paul LARGETYPE Schuster0
I couldn't use the right one......my car came with with modern gas guage0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 68 Hudson 8
- 592 Vehicles
