napa part numbers
2manyprojects
2manyprojects Expert Adviser
for a 51 commodore 6  front shocks and stabilizer links and bushings need current part numbers. also coil springs number. thanks
  • Kdancy
    Kdancy Senior Contributor
    Go to Ken Cates Hudson Restoration site. The info you seek is on there.
    http://hudsonrestoration1948-54.com
  • J Spencer
    J Spencer Expert Adviser
     Monroe shocks, OE Spectrum # 5751 Front (LE10001), rears Monroe Matic Plus # 31094  @Rock Auto about 20 bucks each or local parts stores. Punch in the part #'s as they may not come up in vehicle search. Sway bar links Moog #K 8998. Fits GM Grand Prix, Chevelle, Regal, 78 up.  Dale Cooper sells an upgraded sway bar (from 3/4 inch to 1 1/4 inch) comes with frame bushings, brackets and links for about $220.00  I have one on my  51 Pacemaker, improves handling. He may have springs also.  There may be other shock #'s depending make/ line of shocks..
  • J Spencer
     Monroe shocks # 5751 Front, rears # 31094  @Rock Auto about 20 bucks each or local parts stores. Punch in the part #'s as they may not come up in vehicle search. Sway bar links Moog #K 8998. Fits GM Grand Prix, Chevelle, Regal, 78 up.  Dale Cooper sells an upgraded sway bar (from 3/4 inch to 1 1/4 inch) comes with frame bushings, brackets and links for about $220.00  I have one on my  51 Pacemaker, improves handling. He may have springs also.  There may be other shock #'s depending make/ line of shocks..
