Distributor questions
Yes you can. There may be some variation in the degrees of advance, but as a "get you home" it will work fine.
Thank you Geoff is there anything special I would need to do it? I was thinking of putting a set of points in it as it has none. I have the pertronix in my 39 now but if that fails along the way I would like a back up0
Would pay to check the condition of the advance springs. A set of points and a condensor should get you going.
Ok thank you so much0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 28.4K HUDSON
- 990 Street Rods
- 71 Hudson 8
- 592 Vehicles
