vacuum windshield washers
Can't see the future, so can't answer that question. Hook up the system and see!
Have you had the wiper motor rebuilt or at least lubricated? That will help.
Even when new, vacuum wiper motors would stall when cars accelerated. That held true for all makes, not just Hudsons. That's why they made double-action fuel pumps, which make the wipers run much better. If you don't have them, you might think about installing one. Trico made an Electro-Vac vacuum pump, but they're scarce and expensive. Some folks have made six volt wiper motors that can be adapted to Hudson wipers but I'm not sure if they're still being sold.
My vacuum wiper motor is rebuilt I am asking about how the Vacuum windshield WASHER
pump works. Do they supply enough fluid to wash windshield. Ray
Welllll. As in any such project, the end result is very dependent on the condition of the components in the system. Even if you have an "NOS" set-up, it may have leaky parts in the vacuum circuit due to age, esp. the diaphragm in the pump. If all is good and clean, it will work fine but don't expect the "pressure-washer" output of modern systems.
The vacuum pump is a vacuum-cocked, spring-pressure-applied mechanism, so spring health is a factor as well.
To quote the part that Jon said (that applied) "hook it up and see!"
F
Oops, sorry about that! I saw "washers" and read: "wipers!"
Before you install the whole system in the car, you could just set up the components on a bench next to the car, then run a vacuum line to the manifold and test the system, to see how much of a spray you get from the nozzles. That way, if it doesn't work so well, you could have the time to iron out the kinks before actually putting it into the car. Just a thought!
No problem Jon and thanks for everyone's help. Ray
Hmmmmm. That is a good idea.
F
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 28.3K HUDSON
- 989 Street Rods
- 68 Hudson 8
- 591 Vehicles
