31 essex clutch
That is correct, thee is a pipe plug with a hollow square fitting on the front of the flywheel0
("Passenger side" depends upon what part of the world you live in, LOL!)
Lol that is true sorry0
What's the best way to line the
plug up with the hole on the frontmof
flywheel?0 -
Let's get our terminology straight. The hole is in the engine plate. the plug is in the flywheel. You use the crank handle to turn the engine over until you can see the plug through the hole. If you don't have a crank handle you will have to "nudge" the engine with the starter motor.0
Ok sounds good thanks for you help0
