1928-29 Steering Reproductions -- is anyone making these?
The late Ron Borkhuis used to make the following repro parts. I wondered if anyone is now making those?
I am trying to update my Hudson Repro Parts webpage. http://www.detailedconcepts.net/Repro_Table.pdf
1. Steering wheel lower hub (solid machined from alum. bar stock; straight sides, not tapered as orig.) 28-‘29 Essex & 29 Dover
2. Top steering wheel components: horn button, light lever, throttle lever, outer ring made from modern, sturdy hard rubber material. 28-‘29 Essex & 29 Dover
3. Top steering wheel components: horn button, light lever, throttle lever, spark advance lever, made from modern, sturdy hard rubber material. ’28-‘29 Hudson
Geoff Clark (New Zealand) reproduces the steering wheel hub for the 28 Essex
Gary Lynch (Canada) reproduces the steering wheel hub for the 29 Essex
Thanks!. . . .
I believe that Geoff also makes the 29 Hudson steering wheel hub.0
- 84 Hudson 1916 - 1929
- 18 Upcoming Events
- 68 Hudson 8
