parts
essexcoupe3131
Hi all, been going through my bits and pieces that is access to my needs and have com up with the following parts, I was going to put on eBay but thought I would ask if any 1 is interested here 1st, they are a mixture of bits and pieces
A butterfly nob for the front seat adjuster 30-31 and may have the worm as well or its what I think it is
Set of 30 bonnets no hinge no rust
chromed wooden wheel bolts I think
A 31 Radiator surround only needs a little work cracked on the bottom but all there and solid, also 90% of the grill
A pitted 31 grill frame
the clips to hold on the rear guards
a 30 +31 dash surrounds for the gauges
31 Dash
Gauges that look a bit tatty
valances for a 31 don't know if original or remade no rust sand blasted
31 running boards remade need minor work to finish no rust
a Hand made 31 surround that would work good for a Rat rod
31 radiator surround rusty but maybe good for parts
31 front floor pans and front bulk head panel been altered a bit but easily taken back, nearly perfect, some plates have been tack welded in to fill holes
30 31 interior handle
front radiator valance solid but needs some minor work no rust
Nobs for gear shift not sure what years
Walt ham speed o
rear window nob 28-31 not sure what year
red Essex grill badge
couple tatty 29-31 grill badges and some that were re chromed but need enameling
pair bronze 27-28 side light storks and 4x side lights no glass
I have other part like roof reinforces to the corners some worm set ups with the nobs, some small mechanical parts or linkages
open to reasonable offers
Mike
31 Dash
Walt ham speed o
Mike
